Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 04-13-2011, 04:55 PM   #1
Backyard Ground Is Lumpy... Thoughts?
Hi -
Every year my backyard gets more and more lumpy and hard to walk on. The ground gets so soak from winter and rain that when I cut the grass or walk on it you can see my foot print. Which I'm sure is where the lumpy part is coming in.
Any thoughts on what I can do to fix that issue without going broke? I also tell my wife if I could just get a steam roller and roll out the bumps.
Regards,
David
ostinoh is offline   Reply With Quote
Old 04-13-2011, 05:05 PM   #2
BIGRED
Actually you are on the right track. Go to one of your local rental centers and rent a small self powered roller. They should have both the walk behind kind and the ride on kind. They should be able to deliver and pick it up afterwards too if you don't have a trailer or a vehicle to tow a trailer. You should be able to get a 500-1000 lb. roller and do your whole lawn twice. Once North-South and once East-.West
Grampa Bud is offline   Reply With Quote
Old 04-13-2011, 07:06 PM   #3
Lumpy is likely from frost heaving. Lawn rollers are great, but make sure the ground is soft, but not soaked or you'll just make trenches with a lawn roller. After rolling, next season or so you may need to use a plug aerator if your lawn compacts a lot. If you don't have too many trees (roots/obstacles) it should be a pretty simple to smooth the lawn.
sippinjoes is offline   Reply With Quote
Old 04-13-2011, 08:42 PM   #4
Thank you both for the fast responses. I will try what was suggested this weekend.
Old 04-13-2011, 09:53 PM   #5
sdsester's Avatar
This is the approach. Personally I would aerate once a season as a matter of course though.
sdsester is offline   Reply With Quote
Old 04-14-2011, 08:35 AM   #6
Does aerating my lawn help with drainage as well?
Old 04-14-2011, 08:49 AM   #7
BIGRED
It could if you have soils in your area with high compaction rates (more clay type soils). Aeration is meant to loosen the soil around grass roots so that they can breathe easier and get more water and nutrients to them faster. Then the grass will be greener and thicker and you can cut it more often and the oil companies will be exuberent with glee because you will need more gas for your mower.
Old 04-14-2011, 09:17 AM   #8
the Musigician
DangerMouse's Avatar
My lumps always seem to come from moles/voles.... Po)
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-14-2011, 03:00 PM   #9
sdsester's Avatar
As mentioned it is mainly to provide channels for fertilizer, water and air to get to grass roots and is a necessity with clay soils. In the turgrass industry we did it once per year when we could.
Aeration will do nothing for major drainage issues and overall grade problems. You will probably have to pull the sod up and level those out with quality topsoil and ammendments.
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Uneven Lumpy backyard Mssnglnk Landscaping & Lawn Care 8 06-10-2007 10:54 PM
