Backyard Drainage - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-20-2009, 09:47 AM   #1
Backyard drainage
On both property lines I get standing water when it rains. I recently installed a dogeared fence and noticed that 24" down is clay and shale.
My questios is, if I dig a trench on both property lines and backfill with
gravel and perf pipe will this take care of the problem?
rick32 is offline   Reply With Quote
Old 08-20-2009, 10:23 AM   #2
Is there a lower area where this will then drain?
Or will it lead to an area without the clay layer?
Old 08-20-2009, 02:57 PM   #3
Registered User
Rewards Points: 5,216
Probably, if the water in the french drain is removed to another location. Either by gravity or a sump pump. Put one in that can be easily cleaned: http://www.easydigging.com/Drainage/pipe_tile.html
If needed: http://www.easydigging.com/Drainage/..._soakaway.html
And: http://pwd.org/pdf/water_resources/c.../dry_wells.pdf
Be safe, G
Old 08-21-2009, 07:58 PM   #4
Unfortunately these are both low laying areas and I was hoping for some meracle seepage. One side is baracaded by a garage foundation the other is blocked by a 65' pine tree.
Old 08-21-2009, 08:05 PM   #5
If you can dig down past the clay & use gravel in the drainage ditch then it might help
It all depends upon what is under the clay as far as soil
Of course of the shale goes down deep then your outta luck
Can you install a sump pump & pump it to the other side of the garage?
Old 08-23-2009, 09:35 AM   #6
TooledUp
Where do your downspout go?? If you have them tied into an underground drainage pipe I would put in a rigid drain pipe and tie into it.
TooledUp is offline   Reply With Quote
Old 08-25-2009, 11:34 PM   #7
Sorry it took me so long to reply. I have a lot of irons in the fire here. By the way, whats a down spout? (hehe) I discovered that if the rain lets up
for a day, the standing water dissapates which tells me there is some drainage.
Backyard Drainage How Deep? dbeers16 Landscaping & Lawn Care 12 07-21-2009 09:41 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 01:05 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 02:22 PM
BackYard needs Help ASAP!! Pics included fiji-fa5 Landscaping & Lawn Care 20 04-29-2009 09:00 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 08:38 PM
