Backfilling Trench When Full Of Water - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 11:45 AM   #1
I can fix that!
Rewards Points: 35
Backfilling trench when full of water
I just replaced my water line from the meter to the house with 1" Poly. It started raining heavily the day after I completed the install and now the 25' trench is full of water, and all my fill dirt is now saturated. It looks like the rain won't be stopping here for weeks. Do I need to wait until everything dries before backfilling to properly compact the soil, or will backfilling with wet soil in a water filled trench result in good compaction (I feel like I've heard the wetting fill dirt aids in compacting it)?
kuhlman is offline   Reply With Quote
Old 01-19-2012, 11:49 AM   #2
I can fix that!
Rewards Points: 35
The trench is 36" deep and the soil has high clay content. I also have a pump so could pump out the majority of the water first.
Old 01-19-2012, 11:50 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I've never seen water stop anybody from backfilling.
titanoman is offline   Reply With Quote
Old 01-19-2012, 11:53 AM   #4
Rewards Points: 13,300
It's going to stay muddy and once dry will tend to settle so do not haul away extra dirt if there is any until it's back level again when it drys out.
plummen (01-28-2012)
Old 01-19-2012, 11:54 AM   #5
concretemasonry's Avatar
Rewards Points: 2,578
You are never going to compact saturated soil. A little moisture aids in compacting dry soil, but it is very easy to get too much water.
With a clay soil, you are going to have to wait quite a while to get the moisture down. Rock could provide some stability and displace the wet soil, but depending on the shape, it could damage the 1" poly.
Dick
concretemasonry is offline   Reply With Quote
Old 01-19-2012, 01:09 PM   #6
Civil Engineer
Rewards Points: 4,568
Structural fill typically consists of sand and gravel with a relatively small (less than 20% by weight) silt content. If the silt content is below 5 percent, it is possible to compact structural fill even when saturated, although it may be an unpleasant task. You state you have clay soil, which is typically unacceptable for structural backfill for commercial projects.
Typically, structural fill (meaning fill intended to be compacted) cannot contain clay, organic material, garbage, or more than 20 percent silt by weight. So if you want to backfill that trench and get reasonable results, I suggest you purchase a sand/gravel mix, or you can even use 3/4 inch crushed stone, with a small amount of topsoil (say 6 inches) on top to support seeding. You can place crushed stone/sand mix when it is saturated, and compact it even if saturated, using ordinary equipment like a mechanical tamper.
If you don't care to pay for backfill material, you can fill using the clay soil you have, understanding that it is not going to be possible to compact, so you should expect long term settlement over the trench.
Old 01-19-2012, 02:58 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... If this area sees nothing heavier than foot traffic,...
Go ahead, 'n fill it in with yer spoils...
If it runs across yer driveway, fill in a foot of sand, then finish filling with crushed stone....
Old 01-21-2012, 10:04 PM   #8
Msradell's Avatar
Rewards Points: 128
+1 ding ding ding we have a winner!
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 01-23-2012, 11:51 AM   #9
I can fix that!
Rewards Points: 35
Well, I did it. We had a slight break in the rain on Saturday and I pumped out all the water and filled in the trench with the saturated dirt, tamping the best I could (though tamping just created soupy mud pies). If it ever dries out, I plan on trying to compress it more. Oddly enough, I used all the dirt I had from digging the trench and I will still need another yard or so to bring it back up to grade. My only concern is I was not able to ensure the pipe was support underneath where it goes into my foundation, and where it connects to the lead coming off the meter. I'm crossing my fingers on that.
Old 01-23-2012, 01:48 PM   #10
Civil Engineer
Good to hear you successfully filled the trench. A couple of things to bear in mind. The soil you placed is going to settle over time, there is little point trying to compact clay or silt while it is wet, it acts like jello and never compacts, better to let it dry and settle naturally, then fill to grade in a few years to make it look pretty.
The reason clay and silt is never used in commercial backfill operations is that it exerts substantially more pressure on the pipe than sand or gravel. This may seem counterintuitive, but the sand and gravel (structural fill) bridges nicely over pipe, and reduces the pressure considerably, whereas clay and silt do not, especially if saturated. This is important in deep fill situations with relatively weak pipe, for example installation of HDPE culverts under signficant fill conditions, use of thin walled plastic irrigation pipe, etc. Unlikely to be an issue in your case, but if you ever have to run relatively lightweight pipe for any distance, you would do well to spring for some decent fill material, it will increase the probability of a successful installation.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
concretemasonry (01-23-2012)
Old 01-24-2016, 09:53 PM   #11
Rewards Points: 50
Sorry for digging up an old thread; I wanted to use PM, but apparently I don't have enough posts yet.
Question for kuhlman: I'm also in Portland, and am up against the same issue right now. We had a new sewer line put it, but it was raining heavily and the project took longer then expected, so much of the trench was backfilled with water-saturated high-clay soil. Just curious - did you ever run into any problems with your backfilled trench? How long did it take to dry out enough to walk on without sinking? Has it settled significantly?
(The sewer pipe itself was supported and covered over with crushed rock, but then the remaining 7' depth was backfilled with soil.)
philsmith22 is offline   Reply With Quote
Electric and Water lines in same trench lond Electrical 12 01-09-2011 06:48 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 08:45 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
