Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-09-2012, 02:16 PM   #1
Backfilling next to vinyl fence.
Ok every one. My name is brian, this is my first time posting here and I'm hoping someone can help. Im trying to fond a way to fill the gap between the fence and the current ground. ie I want the ground to be up against the fence.
what are some ideas. do you think it will support the weight of wet dirt if I just throw in the dirt without adding any extra support.
brianb1998 is offline   Reply With Quote
Old 10-09-2012, 02:55 PM   #2
I would not just backfill to fence.
Need to do some sort of retaining wall.
mae-ling is offline   Reply With Quote
Old 10-09-2012, 02:59 PM   #3
Why in the world is that fence installed that way, and why is the ground dug out like that?
If you tryed back filling that fence it's going to just bow out and break, may even tip over.
Old 10-09-2012, 03:09 PM   #4
the ground isnt actually dug out . when they developed the land there was no fence. the neighbors house was below mine so his basement would flood so they built up he plot I'm on using boulder. I had the fence installed down below so i can get and extra foot or 2 of yard. I figures I can fill right against the fence but what about putting pressure treated 2x12 post to post then filling with dirt.
Old 10-09-2012, 03:23 PM   #5
2 X 12's are not below ground rated.
Old 10-09-2012, 04:21 PM   #6
Don't think those posts would be strong enough to support the ground.
Old 10-09-2012, 06:08 PM   #7
the posts are concreted in and steel inside.
Old 10-09-2012, 06:09 PM   #8
JOATMON
ddawg16's Avatar
If you put any dirt up against that vinyl fence, it is just going to bust out through it eventually. Vinyl has NO strength....non....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 10-09-2012, 06:14 PM   #9
no offense to anyone trying to help. I laready know the fence will bow out if I just dump dirt straight onto the fence. Sorry but I dont need to know what I can do. I need to know what I CAN do.
Old 10-09-2012, 06:20 PM   #10
so here are the options I have come up with so far.
2x6 (or whatever is actually rated to go underground) post to post then fill in the areas so there isnt too much pressure on the pannels.
rebar hammered into the ground about every 4ft then add in a couple cross pieces then reinforce that with chicken wire or something similar filling with large gravel/dirt.
5 inch pvc drilled with wholes the while length, maybe 2 or three of those stacked then fill the rest with dirt.
the area is in a dog run so there wont be any significant weight on the area. its mainly aesthetics.
Old 10-09-2012, 06:59 PM   #11
IF and that is a BIG IF, IF the posts are strong enough then use 4x4 or 4x6 or some such thing If posts are 8' centers use 16' 4x4 (4x6) and stack them up staggering joints, drill holes and rebar them together. Put a wider cap on the top (say 2x6 or 2x8) making sure it fills into the Vinyl so stuff can't fall there an become unsightly.
All lumber to be underground rated.
You could also build the wall using 'deadheads' for added strength. 4th pic
Old 10-11-2012, 01:09 PM   #12
Are you also raising the level of your land?
Pounding in rebar or stakes may be difficult because the ground out there is mostly rock. Thin sections of soil between the rocks like the mortar between bricks will have difficulty holding stakes.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Vinyl or Wood Fence? hkolln Landscaping & Lawn Care 3 08-22-2012 08:40 PM
Vinyl fence gate rubs adgjqetuo Landscaping & Lawn Care 13 06-20-2012 03:28 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Replacing an existing redwood fence with vinyl shortmort37 Building & Construction 5 07-29-2011 07:16 AM
Existing Vinyl Fence, Add Lattice to top? benlittle Landscaping & Lawn Care 0 05-30-2010 12:48 PM
