Back Yard Advice / Water Trouble - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 10:38 PM   #1
Jordan83
Send a message via AIM to jordan83 Send a message via MSN to jordan83
My wife and I live in a small suburb of Chicago with a 3 city lot property.
We recently had some tree's removed due to a carpenter ant problem and are working with a clean slate in terms of the yard space and looking for ideas on how to setup the area / landscape it. I did purchase on an end of season special some outdoor furniture from lowes as well as a pergola to install.
We have one minor issue and the attached photos will explain it all.
1) We have uneven yard space form one of the tree removals
2) Depending on how heavy the rain is we can have water problem
Looking for some advice.
Back Yard Advice / Water Trouble-547764_610328604770_112989949_n.jpg   Back Yard Advice / Water Trouble-257728_591120023920_1675000264_o.jpg
jordan83 is offline   Reply With Quote
Old 04-02-2013, 06:51 AM   #2
Rewards Points: 13,450
As the old root system rots away your going to find that areas is going to continue to sink.
My first thought is to raise the grade in that area
Old 04-07-2013, 05:01 PM   #3
Looks like you have 4-5 downspouts draining into your yard, if you regrade it may fix it but the water has to go somewhere and next stop could be some bodies basement.
Bosma is offline   Reply With Quote
Old 04-07-2013, 05:17 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Ayuh,... Lookin' at this picture, it appears the lot pitches down to the left of where yer standin', is that correct,..??
If so, everything above the crossing walkway needs to be pitched to flow Over the walkway,....
Pull a stringline from the grade at the high side, down to the concrete walkway,...
Fill everything below the stringline, 'n water will flow....
of course, if there's a hump, knock it down,... no need for a dam to block the water...
Then ditto the process from the walkway to wherever down to the left in the picture, 'n hopefully safely off the property...
Tags
backyard , flood , help me please , landscaping , lawn
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Back yard redo - Weeds out of control carquote Landscaping & Lawn Care 6 03-03-2012 08:24 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
Trouble with kitchen sink/hot water kid320 Plumbing 3 04-29-2010 10:31 AM
Well Water ? - No water at yard hydrants... but do have water in house mntnvew Plumbing 73 01-11-2010 08:45 PM
