Auger Belt Adjustment On A Ariens Snow Blower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 01:16 PM   #1
auger belt adjustment on a ariens snow blower
I have a model 926007 ariens snow blower and the auger belt needs adjusting, the manual I have is confusing, anyone know how to do it ?
john magee is offline   Reply With Quote
Old 01-27-2011, 01:25 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.... What's it doing, or Not doing,..??
The idler/ clutch pulley is what does the Adjusting....
Old 01-27-2011, 05:43 PM   #3
Civil Engineer
Rewards Points: 4,520
Funny I just adjusted the auger belt on my Ariens, and yes you are correct the manual is confusing. Adjustment is extremely simple. Remove the metal cover over the belt, there are four bolts to do this. Loosen the nut on the center of the idler pulley for the auger belt, I seem to recall it takes a 13mm wrench or so. Then you push the idler inward to tighten the belt enough so that when you pull up on the handle there is no slippage of the belt around the idler pulley. Tighten the nut on the idler pulley, replace cover, have a beer.
Daniel Holzman is online now   Reply With Quote
Ariens snow blower damaged by garden hose Manuelg Appliances 0 01-23-2011 12:56 PM
Noma snow blower Gatineau General DIY Discussions 1 01-16-2010 11:21 AM
Belt care... RippySkippy Tools 3 12-25-2008 02:43 PM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 01:55 PM
Snow blower drive belt replacement help lwhiten395 General DIY Discussions 5 01-15-2008 04:14 PM
