Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-12-2010, 11:29 AM   #1
Lightbulb
Audit your riding mower deck this spring
I suspect few of us give much thought to the deck, even though that's where all the real work is done!
I'm posting this in case it might inspire some of you to check out your mower deck this spring and make any adjustments it might need to get you off to a good start. It's not hard work and it feels great to know that everything's greased up and properly adjusted.
I decided to replace my riding mower blades with new mulching blades and install a mulching cover (didn't have one). I also ordered a new deck belt, as I noticed mine was junk.
This morning I removed the deck, cleaned everything out and greased the blade towers.
The new belt went on easy, as did the blades.
Using the owners manual that I downloaded I discovered that I should adjust the belt tension and then the pulley brakes. One of my brakes was actually dragging! Both procedures were pretty easy.
While I was down there, I noticed that the right side of the deck was about 1/2" lower than the left! Fixed that.
Total time: 3 hours.
tbeaulieu is offline   Reply With Quote
Old 05-12-2010, 11:33 PM   #2
Still going...
ChrisDIY's Avatar
Good tip!
I'm procrastinating on doing this my deck is 1/2" off as well. Will deal with it while I am doing oil change!
--Chris the DIY Guy
Still going, on Ibuprofen...
ChrisDIY is offline   Reply With Quote
Ariens or Craftsman Riding Mower? Osiris Landscaping & Lawn Care 3 04-20-2010 09:46 PM
Murray riding mower Help popcorc Landscaping & Lawn Care 0 01-26-2010 06:43 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
New riding lawn mower mannclan General Discussion 4 08-27-2007 11:08 AM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
