Attaching Landscape Timbers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 01:51 PM   #1
Rewards Points: 117
attaching landscape timbers
im making a raised flower garden bed, im gonna use landscape timbers to make the sides. whats the best way to attach the timbers together and secure it to the ground?
i was thinking drilling a hole thru all the timbers and driving a rebar thru the holes in the timber and into the ground.
is there a better/easier way to do this?
echobravo is offline   Reply With Quote
Old 06-15-2012, 02:17 PM   #2
Civil Engineer
Rewards Points: 4,764
That is a perfectly reasonable way to do it. Another is to drive metal spikes (basically large nails) to connect one row of timbers to another. There is one detail you should think about. If you use PT lumber rated for ground contact, the timber touching the ground will rot relatively slowly. However, ground contract rated pressure treated lumber may be toxic to your garden, so make sure you fully understand what chemicals were used to treat the timber before you use it.
For my money, I would use concrete block to make the raised garden, the type used for retaining walls (segmental block) works really well, and concrete is not toxic to plants.
Old 06-15-2012, 08:08 PM   #3
Rewards Points: 13,694
Read the tags on the ends of landscape timbers.
Says right on the the tag, not rated for below ground use.
Ues 4 X 4's, or 6 X 6's instead.
Each piece needs to have a notch cut out 1/2 way through the piece the width of the material being used.
This way the tops stay level.
I just use 24" long 1/2 rebar to lock the corners.
Old 06-15-2012, 10:50 PM   #4
Drill the Timbers & Use Rebar
I usually drill the timber ends (6" from the end) and every 3-4 feet in between.
I use 3/8" rebar at least 18 inches long to secure them, unless I plan on running over them with a tractor, then I use 1/2" rebar, 18-24 inches. The rebar is installed using a 3lb sledge hammer.
If aesthetics is an issue in the location or you want to be fancy, the timbers can be drilled at an angle from inside the bed so that the rebar doesn't show.
On the corners, I'd drill horizontally and put it in a long deck screw. It's much easier to drill these up on saw horses or garbage cans before they are installed.
Have fun!
ArtF is offline   Reply With Quote
Inferior Landscape Timbers Giles Landscaping & Lawn Care 3 09-09-2010 06:17 PM
landscape timbers reggieh Landscaping & Lawn Care 4 05-16-2010 04:19 PM
Cutting pressure treated landscape timbers; the cuts ? Sven Landscaping & Lawn Care 6 01-20-2008 07:35 AM
Drill bit for landscape timbers ? Sven Tools 6 01-17-2008 08:44 AM
