Attaching A Bamboo Screen To A Brick Wall. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 08:34 AM   #1
Attaching a bamboo screen to a brick wall.
I want to attach a bamboo screen to an external brick wall. I understand there is a method of attaching a wood panel to the brick wall however I was hoping to avoid this. Is there anyway way of simply but carefully nailing the bamboo screen into the brick wall??
Jen23 is offline   Reply With Quote
Old 10-16-2011, 08:21 PM   #2
biggles's Avatar
you could drill into the actual brick(not the mortar) drill with a masonary bit insert a plastic anchor hammer in till flush and screw in the matching screw thru the wood or if it is roped get metal hooks and screw them onto the brick and just hang it
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 08:07 AM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 10:00 PM
Attaching fence post to side of retaining wall? Drew328i Landscaping & Lawn Care 5 06-01-2010 07:53 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
