Attach Landscape Timbers To Foundation? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 02:00 PM   #1
Rewards Points: 14
Attach Landscape Timbers to Foundation?
My home is on a hill and I'm considering terracing alongside the home which has a concrete block foundation. If I elect to use presure treated landscape timbers, is it typical to attach them to the foundation? Are there alternate approaches to make sure it doesn't move (deadmen every other course near the foundation wall for example)?
I've googled and can't find anything on this.
mpls69 is offline   Reply With Quote
Old 04-19-2013, 04:28 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
You are trying to attach a flexible retaining wall to a rigid wall.foundations? - Not a good idea.
If you have frost, it is even a worse idea since it will heave and move differently.
Dick
concretemasonry is online now   Reply With Quote
Old 04-19-2013, 05:01 PM   #3
Rewards Points: 14,010
Got a picture?
Trying to figure out why you think it needs to be done this way.
You do know landscape timbers are not below graded rated and will rot out, right?
Old 04-19-2013, 06:18 PM   #4
Rewards Points: 14
I'm not suggesting it be done a particular way - I'm simply asking the question.
I've seen pros attach window wells for egress windows to the foundation. Do they do this when the well is built with landscape timbers? Don't know, this is why I'm asking.
Old 04-21-2013, 07:21 PM   #5
Msradell's Avatar
Rewards Points: 272
You don't want to attach them for a multitude of reasons. Just install a deadman about every 8' of length on about every 3rd layer, alternating the locations. The deadman anchors should be about 4' long with a cross block on the back end. Also, don't forget to pin the layers together. An easy way is to drill holes in drive in rebar.
Msradell is offline   Reply With Quote
Old 04-21-2013, 11:40 PM   #6
Landscape timbers would be the wrong material to use if it's below grade.
How to stub off an old stone and mortar foundation beautah Concrete, Stone & Masonry 0 04-25-2012 09:43 AM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 09:51 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
mulch against foundation??? fabian Landscaping & Lawn Care 2 05-08-2009 09:38 AM
