Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-12-2011, 11:07 PM   #1
Ariens ST824 problems
Hi, I´m new here and i have an question about my snowblower
I have an Ariens ST824 tek-8hp. I´ve cleaned the carb 3 times now, changed the spark plug, fresh fuel and checked the fuel line, everything seems okey. But it will only start if i put the throttle on low with or without choke. Then it will run for a bit, but i won´t run smooth. If i try to give a little bit more throttle it stops and brigt white smoke comes out of the muffler.
Any suggestions?
kvistern is offline   Reply With Quote
Old 02-13-2011, 09:54 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... It sounds like the Hi-speeds jets inside the carb are plugged...
Old 02-13-2011, 04:20 PM   #3
okey, will try to find a carb manual and check it out..
Thanks!
Old 02-26-2011, 08:31 AM   #4
I´ve tried to clean out all the jets with a compressor, still wont run like its supposed to. I can get it to start like before on no throttle, and it will run for a second or two on full throttle, but it only ignites once a second it seems. Dark grey/black smoke comes out of the muffler on full throttle.
Any more suggestions??
Old 02-26-2011, 08:32 AM   #5
Old 02-26-2011, 11:39 AM   #6
Bondo's Avatar
Donno, but it sounds like it's Still got a Carb problem....
Black smoke says it's flooding out....
Old 02-26-2011, 11:59 AM   #7
I would say a carb issue as well...
Shatinen is offline   Reply With Quote
Old 02-27-2011, 06:10 PM   #8
Hmm... Do you guys have an detailed carb manual or know where i could download one?
Old 02-27-2011, 07:21 PM   #9
Bright white smoke? Could it be water in the gas
http://drygas.com/html/gas_line_antifreeze.html
http://www.acehardwareoutlet.com/pro...rce=GoogleBase
http://en.wikipedia.org/wiki/Dry_gas
handy man88 is offline   Reply With Quote
Old 02-28-2011, 08:46 AM   #10
Bondo's Avatar
Ayuh,... Google the numbers on it...
Tags
ariens, snowblower, st824, start problems
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
Removing pulley on Ariens ST824...PICS J187 Landscaping & Lawn Care 3 10-26-2008 01:10 PM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
