Ariens Snowblower Damaged By "eating" Hose - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 03:39 PM   #1
Ariens snowblower damaged by "eating" hose
Almost new Ariens snowblower damaged by becoming entangled in garden hose. Both pins were sheared but lateral housing of the auger was also deflected outwards. This caused misalignment of bushing which receives the auger axle. Efforts to realign the housing with wrench have not succeeded. Do I need to remove the auger axle? I will be very grateful for any advice. The shop wont take it for 3 weeks!
Manny
Manny32 is offline   Reply With Quote
Old 02-02-2011, 05:00 PM   #2
Rewards Points: 1,494
Is the housing in multiple pieces that can be unscrewed and disassembled? Like take off just the bent side panel?
If you can take the side panel off then it will be easier for you to "bang" it (or wrench it) back into shape.
Otherwise you will need to disassemble and remove the axle.
In order to bang a one piece housing back into shape, it will need to be sprung inward past its orginal shape and then the metal will bend as opposed to just act springy and it will retake the shape it should have.
Don't insert a pole into the bushing itself to wrench the panel back into shape, you willl deform the bushing.
AllanJ is online now   Reply With Quote
Old 02-02-2011, 07:45 PM   #3
Rewards Points: 1,088
Manny
Take it back to home depot.
handy man88 is offline   Reply With Quote
Old 02-03-2011, 08:09 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
go on utube
Somebody on there must have run over their garden hose and is doing a video of how tho repair the auger and how to put the hose away in the fall !!!
tcleve4911 is offline   Reply With Quote
Tags
ariens snowblower repair , auger axle bushing , auger housing
Ariens snow blower damaged by garden hose Manuelg Appliances 0 01-23-2011 11:56 AM
Ariens Snowblower Axle Wont Turn BW02916 Tools 3 11-14-2010 12:45 PM
ariens snowblower george61 Tools 1 08-18-2010 03:54 PM
ariens snowblower traction skidad Tools 2 12-17-2007 04:32 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
