Ariens 824 - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 08:11 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Ariens 824
I have an Ariens 824 snowblower, that the drive gear doesn't seem to be acting right. I do not seem to be able to go thru snow like I use to. I've adjusted the cable, and we had some heavy snow yesterday and I've noticed that I had to push more than usual. And when I got done snowblowing, I was going toward my shed with the snow blower and I noticed black spots coming from under the rear casing. The snow blower seems to be moving fine, just when there is a heavy load it seems to have touble. Now, I don't know if the black drips was just water splashing up inside the case and some oil being mixed with it and dripping down or if I have a problem.
I did not take the cover off the case, because I don't know which way to tip the machine. Also, wouldn't know what to look for.
I don't want to bring it to the repair shop, in case nothing was wrong...he seems to keep the machines longer than needed, and pretty much has the attitude of "it's done, when it's done."
I can't be without my snowblower for weeks.
Any suggestions
Barry
Barry J is offline   Reply With Quote
Old 01-20-2011, 12:35 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,708
Ayuh,... My guess is, the Black stuff is from the drive Belt, 'n you need a New 1...
Bondo is online now   Reply With Quote
Old 01-20-2011, 12:48 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
which way should I tip this thing, towards the handles or the other way??
Old 01-20-2011, 01:22 PM   #4
Bondo's Avatar
Ayuh,... I believe it seperates just forward of the wheels, just aft of the chute...
Old 01-20-2011, 08:01 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
The snow blower still moves, could it still be the drive belt??
Old 01-20-2011, 11:46 PM   #6
A Little Of Everything
Rewards Points: 1,364
Yes, it certainly could be your belt wearing out. It could also be the cable/rod needing to be tightened.
It could actually be several things, but it's really hard to know without some more information. Perhaps even some pictures.
Thanks!
DrHicks is offline   Reply With Quote
Old 01-21-2011, 03:00 PM   #7
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Here are some pictures...see attachments
Old 02-02-2011, 05:55 PM   #8
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
ok, I took it apart, the friction disc is missing about 90% of the rubber. It is suppose to have rubber around it right??
I found bird seed in the case, and I just killed a mouse, I think the mouse chewed on my friction disc rubber or it just wore down after 9 years of use???
The friction plate also has grooves worn into it...will I have to replace both???
Is this an easy job????
thanks
Barry
New pic attached
Old 02-02-2011, 07:01 PM   #9
Rewards Points: 292
Wow that is in rough shape. It will definately need a new friction disk and probably a new plate as well. Have you been to the Ariens site? They have info on your particular model. They will ask you for the model number and maybe even your serial number. They will also have a list of Arien parts dealers in your area.
Changing belts and disks in 10 degree temps in no fun. Once was enough for me. Now, I open her up in the fall and do all those preventative maintenence things.
Jim F is online now   Reply With Quote
Ariens Snowblower Axle Wont Turn BW02916 Tools 3 11-14-2010 12:45 PM
ariens snowblower george61 Tools 1 08-18-2010 03:54 PM
Ariens or Craftsman Riding Mower? Osiris Landscaping & Lawn Care 3 04-20-2010 08:46 PM
Ariens zero turn tractor magnum24 Tools 2 06-11-2009 02:24 PM
Removing pulley on Ariens ST824...PICS J187 Landscaping & Lawn Care 3 10-26-2008 12:10 PM
