Anyone Ever Discovered A Buried Exterior Sump Pump? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 12:51 PM   #1
Rewards Points: 53
Anyone ever discovered a buried exterior sump pump?
While tracing a mystery electrical circuit, I found that one 15amp cord went somewhere outside and quickly came upon what is apparently a non-functional and aging outdoor sump pump.
Any guidance on removal? (Other than shutting power off to that circuit)
I don't need the thing to be functional again as we've since invested in some heavy duty waterproofing elsewhere - although I had been thinking of putting a drain in that very spot and digging an underground pipe about fifteen feet to the edge of our property that slopes to the street.
corsulian is offline   Reply With Quote
Old 07-31-2013, 05:39 PM   #2
DIY staff
Rewards Points: 7,174
You answered your own question---good answer,too!
Retire the electric circuit---dig out the old pit and add that drain---Yep you answered it!!!!
Old 07-31-2013, 06:10 PM   #3
Rewards Points: 53
Done. I may add a drain at a later date with a trench going a bit deeper so that I won't need a pump. If they had just dug 2' deeper, they wouldn't have needed a pump.
Now - free dedicated 20amp circuit!
The Following User Says Thank You to corsulian For This Useful Post:
oh'mike (08-02-2013)
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 07:07 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 10:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
