Any Crabapple Tree Experts? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By stick\shift
  • 1 Post By Bondo
  • 1 Post By de-nagorg
  • 1 Post By ZZZZZ
Old 03-20-2017, 12:38 PM   #1
ZZZZZ's Avatar
Rewards Points: 2,164
Any Crabapple tree experts?
As Bart Simpson would call it , I've got this "cruh-bapple" tree in my front yard.
The top 95% of the tree appears to be deceased, the branches are dry and brittle. At the base of the tree, there is some really nice and healthy new growth. Flowers just bloomed a few days ago.
I'm in sunny AZ, and the tree gets plenty of sunshine, and I do water it once or twice a week in the dry season.
What, if anything should I do with this tree in terms or pruning or cutting to stimulate growth at the top of the tree?
Should I cut anything?
Should I leave it alone?
Should I just yank the whole thing out and plant something else?
Thanks.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 03-20-2017, 01:37 PM   #2
Rewards Points: 652
Re: Any Crabapple tree experts?
IMO, that tree is on the way out. You may get the bottom to grow if you cut off the top but it will never be a good looking tree as a result.
Bondo and ZZZZZ like this.
stick\shift is offline   Reply With Quote
Old 03-20-2017, 02:30 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,.... Agreed,.... If ya wanta Experiment, cut it off just above anything that looks Alive, 'n let it go,...
Otherwise, yank it, 'n start over,....
ZZZZZ likes this.
Old 03-20-2017, 03:49 PM   #4
Rewards Points: 2,018
Winter Kill, is a common malady for many trees.
That occurs most often farther north than you, though not heard of there.
It basically is a quick freeze on the above ground part, and the best remedy is to cut off the dead, before it infects the good root, but the remainder only grows as small branches out from the remaining trunk, and will always look strange.
I have an old cottonwood that looks like a giant slingshot, it has a two foot tall trunk, sticking up and then two ten inch diameter branches reaching up to 50 feet tall.
It was a small tree already damaged this way 35 years ago when I bought the place, and has grown much bigger.
If you want the crab-apple for beauty, you need to replace it, but if you want it for fruit, and shade, cut it above the growth, and allow the growth to flourish as it will not care how it grows, it will be happy growing at an odd angle.
ED
ZZZZZ likes this.
de-nagorg is online now   Reply With Quote
Old 03-20-2017, 05:13 PM   #5
ZZZZZ's Avatar
Thanks guys. I become a tree surgeon tomorrow.
de-nagorg likes this.
Old 03-28-2017, 12:08 PM   #6
Rewards Points: 45
Yeah, prune at ground level and start over. Make sure to look for the new Malus (crapapples) that are disease resistant. Cedar apple rust is very prevalent and over time can weaken the tree to the point it can't fight off other diseases or drought. It looks like you have a bunch of cedars right by this tree so there is no reason, frankly, to plant another crabapple. They will all struggle due to the cycle of disease between the two trees.
Plump is offline   Reply With Quote
The Following User Says Thank You to Plump For This Useful Post:
ZZZZZ (03-28-2017)
Old 03-28-2017, 02:43 PM   #7
ZZZZZ's Avatar
Those are juniper, ash and pine trees nearby, which are native. The crabapple was planted by a previous owner. It did well the first year I lived here, but then the die-off last year. I thought it was totally dead, but the healthy new growth at the base this spring gave me some hope.
I'll give it a shot to recover, if it doesn't I'll plant something else thee.
Old 03-29-2017, 12:03 PM   #8
Rewards Points: 45
That new growth is a response to dying. It will not be a healthy tree. It's called epicormic sprouting and many trees do it as a last ditch effort before total die back. They are not from vegetative buds and will not grow as normal trunks and branches do.
ZZZZZ (03-29-2017)
Any crabapple tree experts out there? ZZZZZ Landscaping & Lawn Care 1 03-05-2016 09:56 AM
Transplant tree near underground utility lines? BrandonC_1972 Landscaping & Lawn Care 11 08-26-2012 05:43 PM
Apple Tree Care bgibson11 Landscaping & Lawn Care 9 05-28-2011 08:28 AM
Extending deck around a tree jcgoldie Building & Construction 2 02-15-2011 05:20 PM
