Any Advice On How To Locate Water Lines? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 09:12 AM   #1
Any advice on how to locate water lines?
I purchased a foreclosed home back in June. It had been sitting empty for the last three years and had been winterized. So far I have located two underground water lines. One going to a sprinkler head, as they seem all over the yard. The other feeding the pool house. And in all fairness, it was the septic tank guy who found that one! I was able to shut the water off at the street and repair those connections. My problem is, I have no idea where any valves are to shut off anything. There is a valve in the house that cuts off water to the house, but nothing outside. I also located the sprinkler box in the garage wall that controls the sprinklers (I think). It has a plug to go into the wall, but I have never tried using it as a bunch of sprinkler heads in the yard look damaged.
The plastic pipe feeding the pool house was blue and the other pipe was white. Is there a way to locate the valve(s) underground so that I can shut them off? With winter around the corner, I see more busted pipes in the future. And I tried contacting the past owners, but no luck. Any advice would be greatly appreciated.
emory is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
correct size pipe for water lines jce Plumbing 2 04-11-2010 08:23 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
