Anti Siphon Valve - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-26-2013, 05:50 PM   #1
analogmusicman's Avatar
Rewards Points: 560
anti siphon valve
I'd like to connect an "anti siphon" valve outside the house just before my 3/4 pipe goes to the valves. I'd like this "anti siphon" valve to have a "port" where I can connect my compressor to "blow out" the lines. where can I get such a thing? or is there some other way to get some air in? I want to "blow out" each zone including valve so there is no water in there to freeze.
tnx,
analogmusicman is offline   Reply With Quote
Old 09-26-2013, 07:17 PM   #2
Rewards Points: 13,458
Need a picture of your set up.
Just adding on of these in a tee will work.
http://www.amazon.com/Amflo-701-2-np.../dp/B0002V4Q4I
Old 09-26-2013, 10:17 PM   #3
Rewards Points: 22
Search for backflow preventer. Watts makes one.
The easiest way is to add a hose spigot on the line and adapt an air line fitting. That's what my irrigation company does when they blow out my system.
http://www.homedepot.com/p/Watts-3-4...3#.UkVxXBDVEU4
Dan
djlandkpl is offline   Reply With Quote
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
