Another Snowblower Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 03:18 PM   #1
Rewards Points: 160
I have a White brand snow blower, a Snow Boss 750, in fact, that has a couple quirks. It is 8 or 9 years old.
It starts great, first pull out of the shed this year even. But I have to follow a very specific starting order: full choke, 3 pushes on the primer bulb, pull to start, then half choke for a minute or two until it's ready for action. But that's not what's bothering me.
1. the throttle lever no longer turns the machine off like it used to do. Now it just goes to low idle. Even if I turn and remove the big red plastic key the engine won't turn off. Any ideas? I've resorted to just pulling the spark plug wire. Not the end of the earth, but the occasional shock is annoying. I've been meaning to buy a wire puller, but you know that's gonna get lost...
2. When there is no load on the engine the rpm's surge in a hi/low way at about 1 hertz. As soon as i give it some snow to deal with, it evens out. Again, nothing I can't live with, but is it a sign of some other problem developing?
Thanks!
cgoll is offline   Reply With Quote
Old 12-21-2010, 08:29 PM   #2
Rewards Points: 1,088
Thanks!
Maybe the carburetor is stuck open. Try some Gumout.
http://www.amazon.com/XTRA-CARB-CLEA.../dp/B000PD22FS
Your throttle is probably adjustable too.
handy man88 is offline   Reply With Quote
Old 12-21-2010, 09:25 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 328
Ayuh,... #1, the shut-down has lost it's Ground.... loose screw, broken wire, whatever..
A jumper wire from ground to the sparkplug is less shocking than pullin' the wire off....
#2, I agree is probably a crud in the fuel system issue, probably the carb...
Old 12-21-2010, 10:46 PM   #4
Rewards Points: 160
Lost ground would make sense; I have had a problem w/ mice in my shed chewing on wires.
And I'll try some carb cleaner and maybe some Seafoam in the fuel.
Thanks for the advice!
Snowblower Electrical Question TimKLL Automotive Repairs 3 01-20-2011 08:10 PM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
