Alternatives to Monkey Grass? (Mondo grass)
Hi, we have huge Monkey grass (I don't care if you call it Mondo, we don't in the south!)... that borders all our beds and shrubbery. I'm actually kind of tired of it. The clumps of the monkey grass are HUGE, even if we trim them back... so it just doesn't look organized anymore.
I was thinking about digging them up and using something cleaner for a border, possibly brick that matches our house, and some smaller type of plant behind the edging. Do you know of any other plants that would be an alternative to monkey grass? That still has that bordering look... I appreciate it! |
Monkey grass and Mondo are two different plants. You have liriope. You may want to conseider mondo or dwarf mondo. Very low maintenance, excellent border plant.
That goes against the common thinking over here Kap...where do you get your source of info? Mondo=Monkey=liriope...
:yes: |
seems google can't decide either. these are 3 different quotes i found....
All monkey grass falls into two categories: Liriope (lily turf) or Ophiopogon ( mondo). Mondo grass (monkey grass) is related to liriope but not the same plant. Often confused with Liriope, the Ophiophogon japonicus has narrower leaves, smaller flowers and bluer fruits. Similarly, many people assume that Mondo grass and Monkey grass are the same plant with two different names. Although many gardeners will tell you the same thing, there is actually a difference between the two. For instance, Mondo grass feels smoother and grows taller than Monkey grass. Mondo grass bulbs are also bigger than Monkey grass. All of these translate to Mondo grass being more difficult to manage and get rid of, in comparison to Monkey grass. you decide.... lol DM |
Class project: Where did the name Monkey Grass come from for either? |
http://www.ctahr.hawaii.edu/oc/freepubs/pdf/OF-28.pdf http://www.ctahr.hawaii.edu/oc/freepubs/pdf/liriope.pdf |
| All times are GMT -4. The time now is 12:37 PM. |
