-   -   Advice needed for draintile under sidewalk (http://www.diychatroom.com/f16/advice-needed-draintile-under-sidewalk-50412/)
dgbehrends 08-07-2009 12:30 AM
Hi and thanks or reading,
I've got a downspout that feeds into a flower bed next to my house. When we moved in a year ago water from the downspout led to some moisture and efflorescence on the concrete block in our basement. A quick fix was to put bendable drain tile on the downspout and redirect the water across a sidewalk and down a slight grade away from the house. Now it's time for the real fix and here is where I need some advice. The sidewalk is 4" thick and about 3'6" wide with an inch or so of crushed rock underneath. I want to route the water under the sidewalk and out to a pop-up near a tree in my front yard. The grade should allow it.
I need to dig under the sidewalk and have read that using a PVC pipe with a water hose will get me through. The drain tile is 4", so how big of PVC pipe should I use to blast the water through?
I also have a pressure washer, should I use that instead? Should I put the drain tile right underneath the sidewalk or go down a few more inches?
I don't want to create a mosquito hatchery so I was thinking of using perforated drain tile however a neighbor warned me that it could heave my sidwalk??? Anyone have experience with this?
How about just plain straight PVC under the side walk part and perforated drain tile for the rest?
Do I need to wrap it in the white fabric wrap that I've see available?
All comments and suggestions are welcome.
Thanks.
concretemasonry 08-08-2009 12:04 PM
Since you are trying to carry water to a location, perforated pipe (especially corrugated) is the wrong material to use. Use smooth PVC.
A pop-up is nice, but make sure you have an alternate plan for late winter and early spring when the ground is still frozen. I often have to disconnect my pop-up line and use a surface discharge system once every couple of years. - Not enough snow for insulation and slow thawing because it is on a NE corner of the house.
dgbehrends 08-08-2009 12:41 PM
That makes sense to me however I have read else where the corrugated drain tile is what people generally use for this. In theory I don't want any resistance to my water flow so it would make sense to use smooth PVC, just like the gutter down spout is smooth.
I also don't want standing water in the system so do I need to drill small holes in the smooth PVC to ensure it will drain? and make sure I have pea gravel underneath the spots I believe the pipe will need to drain?
If there is dirt buildup in the pipe, I could take the pop-up off and use my pressure washer to blow it out.
Landscaper1 08-09-2009 07:42 AM
We encounter this numerous times when doing concrete pavers or directing water from existing downspouts. We prefer smooth PVC for under the sidewalks or pavers, then connect to a PVC with holes drilled for drainage (you can buy already drilled). We wrap the drilled section with spun bound landscape fabric and we put 3/4" clean concrete stone (pea gravel could also work) under the drilled section - about 6" deep or so depending upon soil type. We also dig a hole if you will where the pop up is - similar to a french drain. We drill holes in the pop up elbow section to make sure no water is sitting anywhere along the tube. Hopefully this helps.
dgbehrends 08-09-2009 10:50 AM
Hi, Yes this is very helpful. I will plan on doing something similar.
dgbehrends 11-17-2009 01:03 AM
My project is done. It took a few hours of work but it worked out well. I was going to use a water jet to dig the whole underneath my sidewalk but decided to try digging from each side first before I got messy. After digging a little over a foot in on each side I had an idea for a tool to dig the rest of the way. I cut a 4 foot section of my 4" PVC pipe and then cut triangular teeth on the end of it. I used this tool to dig the rest of the way under my sidewalk. I would ram it in, turn, and pull out. I dug right through in about a half hour and not much mess. To finish the project I put pea gravel under the sections of the pipe that had holes. I used 4inch straight PVC with no drain holes in it under the sidewalk (to avoid any frost heaves of the sidewalk) and then transitioned to 4" sewer pipe (allows the water to drain out and not become a mosquito hatcher), which is identical to 4" solid PVC except that it has 3 half inch holes on the bottom of it spaced every foot or so. I wrapped the sewer pipe section in a fiber mesh designed to keep crud from entering the pipe and then installed the pop up and buried everything. I used a level to make sure I had a grade all along the pipe. So far it is working great. I need to install a filter (probably a metal mesh or plastic grate) in between where the downspout comes down and the 4" piping starts. Right now not much gets into my gutters but in a few years when my trees are taller it will be a different story.
