Adjust-A-Gate Opinions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 12:00 PM   #1
Long story short. I have a concrete pad in my backyard I want to use for my boat. Existing gates are 90" wide, two gates each 90". I bought the house with the fence and the gates are 99% wood with metal frames at the corners. Gates need to be replaced as they have sagged to dragging AND the cross members have begun to crack. Hinges don't look anywhere near sufficient enough. I am planning to replace the gates and hardware and I ran across the "Adjust-a-gate" system online. It is a steel frame used for gates. Seems a little more convenient than having a custom frame fabricated. Any of you have experience or opinions on this product? Link is below:
http://adjustagate.net/
Swampworks is offline   Reply With Quote
Old 06-09-2011, 07:09 PM   #2
Howdy Swampworks,
I've dealt with sagging gate kit's and they usually are very effective. The idea is they create the support of the gate in angles that are weak. I would make sure to always use washers to keep the lag bolts secured. As a quick reminder, a level and measuring tape will save you a lot of time too.
Coach Dave
Home Depot Expert
CoachDave is offline   Reply With Quote
Suggestions for a 12ft wide wood gate? bikerider138 Carpentry 14 12-07-2010 10:40 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Driveway Gate Post. Is this deep enough? MexTex Building & Construction 2 09-10-2010 04:06 AM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 08:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
