Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-29-2009, 10:46 AM   #1
Adding Sprinkler Valve to Existing zone
I am wondering if anyone has a suggestion on how to add a new sprinkler valve to an existing zone. My current zone has about 12 heads on it and the grass has gotten pretty thick thru the years and it's hard for the sprinkler head to pop up all the way. And it's not as strong so coverage is not as good. How do I split the zone up. I see extra wires that I can use, but I don't know how to find where to split ? Any help would be appreciated.
tilphan is offline   Reply With Quote
Old 03-29-2009, 11:14 AM   #2
Remodeling Contractor
The sprinkler heads can be changed to allow a higher popup or better spread. But seems like you have too many on one zone now. You will need to add another in-line valve and install it in the middle of the existing run. End the first part at that point and tie into the last heads with this new valve. Check out a some online supplies, they offer good guides.
Old 03-29-2009, 12:27 PM   #3
Gus
Sometimes the grass just grows over the head a little and needs to be cut out around the heads. They actually have a tool for this, but an old kitchen knife or something would work.
When I say cut out around it, I don't mean the length of the grass. Actually cut the sod out around it. Cut out about 1/2' around each head.
Gus is offline   Reply With Quote
Old 03-29-2009, 01:35 PM   #4
Gus, I've seen people do that here in the neighborhood. That does work, but it makes your lawn looks like it has ball spots. Especially around the edge of the side walk.
I believe that enough pressure will be able to push heads thru. I've normally go around and cut the grass at the head so that it pokes thru and that doesn't destroy the look of the green lawn. But the weakness due to to many heads in the long run is the true problem.
I've gotten them to come out back when the house was built and I didn't realize at the time that all they did was to lift the heads up with a shovel. Well my yard doesn't sit on limestone or hard rock so eventually it sinks back. I've DIY most of them by putting extension on them so that they are now at gnd level.
I want to split the valve for pressure and coverage. Even if I change the spread, the weak pressure will cause uneven coverage.
Thanks for all the tidbits.
More On This Topic
Getting Proper Coverage with a Lawn Duster
Getting Proper Coverage with a Lawn Duster by eHow Home & Garden Editor
Getting proper coverage with a lawn duster is easy with these tips, get expert advice on lawn care and maintenance in this free video. Read More »
Weak passes and passing a basketball into cover are two mistakes poor basketball players make. Watch a basketball coach demonstrate passing mistakes with his players in this free video series on basketball offense. Read More »
Pressurizing a Lawn Sprayer is easy with these tips, get expert advice on lawn care and maintenance in this free video. Read More »
Many auto repair kits contain battery-powered air compressors, which can be used to pump up a tire when it goes flat. They are simple to use and don't require much dexterity, though they may pose difficulties if you're not mechanically inclined. Read More »
DIY Soundproofing
DIY Soundproofing by Arthur Noxon
In DIY soundproofing, sheet rock needs to cover any windows. Soundproof a room personally with tips from an acoustics specialist in this free video on soundproofing. Read More »
HOW TO diagnose gas valve problems Nestor_Kelebay How To Guides 5 03-07-2010 03:35 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Sprinkler System - Installing Valve Box tazmajazz Plumbing 3 01-06-2009 10:14 AM
White-Rodgers zone valve 1361 wiring ??? srauner HVAC 1 12-07-2008 12:50 AM
1 1/2 inch zone valve - can't find BOUTYM HVAC 2 11-20-2008 11:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
