Adding Mulch - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 10:02 PM   #1
Adding mulch
I am adding 3" of new mulch to my landscape areas. The existing is a thin layer of older mulch and can I just add new mulch on top or do I need to rake the existing first? Also, if we want to plant some annuals later, is it just a matter of moving some of the mulch until to get to the dirt and plant and plce the mulch around the new plants?
Tim
howard.wheaton is offline   Reply With Quote
Old 05-03-2009, 10:49 PM   #2
I just add the new mulch on top
If I need to add plants I push the mulch aside to get to the dirt
Then move mulch back around the new plants
Old 05-04-2009, 09:58 AM   #3
Old mulch will break down into nutrients, and is great for adding to heavy clay soil.
I'm not sure about the various kinds(we have cedar), but pine-mulch might damage new plants as nothing grows around the base of pine trees.
Stillwerkin is offline   Reply With Quote
Old 05-04-2009, 12:26 PM   #4
I've never used weed sheet anywhere
And I have a ton of gardens
I also use very little mulch
Once my gardens grow in weeds don't have a chance
Old 05-04-2009, 04:23 PM   #5
Don't know it all, yet!
Where are you?
What material are you using? That's about right for pine straw, but getting deep for bark.
Not true. Many plants will grow under the filtered shade of pines whereas they will not under denser shade of trees such as oaks. Not to mention that the roots of oaks and others will suck the moisture away from ornamentals planted within their root zone. Also, I don't know what folks use in your area, but in the south, pine straw and pine nuggets are the mainstay of landscaping mulch.
I don't use fabric. Weeds will germinate in the mulch on top of the fabric, and if you try to cultivate later, the fabric gets in the way. At least in my experience.
Mulch is primarily for moisture and temperature control. Weed control is more of a by-product. I strongly recommend using a pre-emergent for weed control.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
mulch fade pfisch Landscaping & Lawn Care 3 04-25-2009 08:06 AM
Adding Lava rocks and remove old mulch kirridam Landscaping & Lawn Care 5 02-11-2009 12:18 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
Playground Mulch Texas Cheesehead Landscaping & Lawn Care 13 06-19-2008 08:03 PM
