Adding Lawn Next To House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 08:38 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Adding lawn next to house
I have a small passageway between the house and the hedges which had patio stones on it. I removed the patio stones and I just want to put grass there. Part of the reason is to help with irrigation a bit. The grass roots should help absorb some of the water, and it will also create a tougher ground to drive extra water away, compared to just the sand that is there now. Even with the patio stones, water just got in between and such.
I will want to slope it away from the house a bit too. How think of black earth should I be adding if I want to grow grass? Also, should I dig along the house and add some tar paper or something? Or is there something I spray/paint on? I noticed in some spots there is black stuff that is visible, so I'm guessing this is a tar based substance of some sort. I will want to bring that up a bit higher I guess.
Anything else I should maybe know when getting grass to grow where there was none before? Also does grass need lot of sunlight to grow? This is in a rather shady area. Wondering if I'll have trouble getting it to grow.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Moisture concerns with adding framing to old brick house Stemboat Building & Construction 2 07-15-2010 09:04 PM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 10:50 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
