Adding A Head To A Line - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 10:41 AM   #1
Ka Ciao
Adding a head to a line
Is it bad to add an additional sprinkler head to an area? I'm wanting to put a flower bed in the middle of one of my areas. I have a sprinkler that sits right in the middle and want to split the area this sprinkler covers with two heads on each side of the bed.
kadesmith is offline   Reply With Quote
Old 06-21-2012, 11:43 AM   #2
Rewards Points: 3,742
Two heads might be a bit much, one on each side shouldn't be a problem.
Canarywood1 is offline   Reply With Quote
Old 06-21-2012, 12:04 PM   #3
Ka Ciao
lol, I need to check my grammar before posting. I meant one on each side, 2 total.
Old 06-21-2012, 01:37 PM   #4
Go for it,shouldn't be a problem at all.
Old 06-23-2012, 06:25 AM   #5
Too Short? Cut it Again!
Adding a sprinkler head should not be a problem but to be sure you should total the draw on the circuit in gallons per minute flow rate and water pressure being demanded. You should also make sure you have adequate water pressure. The heads should have information about flow and pressure demands on their packaging. For a crude calculation you can just add up data for all the heads.
Another thing to think about? Convert you flower beds to drip irrigation. It is good for the environment and great for plants. Drip waters in gallons per HOUR and not gallons per MINUTE and puts water only where you want it. There are seldom issues with running out of pressure or water flow in residential drip irrigation applications.
adding a drain line for a washer harringtongrace Plumbing 0 02-09-2011 11:52 AM
Proper gas line installation for wall furnace rsaritzky Plumbing 2 11-20-2010 12:39 AM
adding 220 line Mikejr05 Electrical 7 06-04-2009 03:45 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
