Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-28-2009, 10:12 AM   #1
Mr. Peters
Smile Adding drainage to existing retaining wall?
Hi all. I live in the North Shore Massachusetts area. My property has a cinder fill block retaining wall probably over 130 feet long with heights sloping from 1 ft up to 6 feet high on the other end. This wall was built back in the 1950's and it is the original wall. Due to having no proper drainage system, the wall is beginning to crack due to freezing and thawing over the winter time. I know this is caused by lack of proper draining system. Can anyone recommend what I would need to do to make a proper drainage system for this wall? I am a DIY and one day the wall will need to be replaced. Landscapers have quoted over $50k to remove and install a new wall system and the stairwell that is attached to it will also have to be replaced. It will take us a long time to come up with the funds but we would like to install a proper drainage system for the time being while we are saving for this future project and to avoid an early wall failure while we are saving. Any ideas on drainage greatly appreciated and thanks in advance. BTW, I saw something on TV about digging a hole every 4 to 8 feet with a fence post digger and dropping in PVC pipes (with holes ?) in the hole and stub the other end of the pipe out of the wall. May require drilling weep holes in front of the wall. Also backfilling the post hole with stones. I could not seem to find any information on such drainage system and what size pipe is needed for each post holes as well as what goes on top of the pipe when it stubs out of the ground. Thanks again.
pcballgame is offline   Reply With Quote
Old 04-13-2009, 09:15 PM   #2
You haven't got any answers because this is not an easy questions. The system you reference would work. I'd use three or four inch perfotrated pipe but I'm a little perplexed on how you tie the weep hole into the pipe.
Having said that the issue is the pressure behind the wall. No knowing how the wall is built or tied back into the bank makes this s little more difficult.
I think I'd get a couple of lengths of 2" or 1.5" diammeter schedule 80 PVC. I'd drill holes that were oversized by 1/4" where the problems were right at the base. Mkae sure these are 3' or so apart. Now you need to be careful because the whole thing could come down on you head and kill you. I'd take a 24" section of the pipe and angle at the end so it coiuld be used like a giant spoon to scoop the dirt out of the hole and do same. Take a section of the schedule 80 that is 2" longer than the wall is thick and insert it into the hole for drainage making it flush on the front. Try a few and see how it works.
Dugger52 is offline   Reply With Quote
Old 04-13-2009, 11:19 PM   #3
Mr. Peters
Thumbs up Thanks
I just want to say thanks to the person who gave the only feedback. I was also able to dig up information from This Old House web site. Here is the URL: http://www.thisoldhouse.com/toh/askt...765678,00.html I have also been keeping an eye on the television station to see if they show a rerun of what I saw in the past as I said in my last post and to date no avail. Soon I will start working on the drainage project.
Old 04-14-2009, 07:15 AM   #4
I debated whether or not to do what was on the link or something similar. The difference is that you have a block wall that is showing damage and there wall was solid poured. In a perfect world you'd dig out behind the wall and lay perforated pipe in a gravel bed wrapped in geo-tex material and run it to day light. With a cracked CBS wall I'd perform the basics as I've outlined and see if that did the trick. If you get digging around behind the wall you could bring the entire thing down.
Do you know where the water is coming from? i would try to deal with that too, if possible.
Old 04-14-2009, 03:11 PM   #5
I have to believe that if a 6' high, 130' wide cinderblock wall built in the 1950's lasted this long, it already has a proper drainage system, and the damage you're seeing now is just because a cinderblock retaining wall isn't going to last forever.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-14-2009, 05:29 PM   #6
Concrete & Masonry
It definately cant hurt to try drilling bleeders thru the wall. As stated before, run 1.5" pvc thru the hole & drill holes in the pvc in the conter. I think it's just as important to drain the water that is inside the block cavitys. Also, drill the holes as low to the ground as possible. You may luck out & find that there may be some drainage stone behind the wall.
jomama45 is offline   Reply With Quote
More On This Topic
Okay we are over here at tub number 2 where we are going to install a PVC pipe drainage system and this pipe doesn't have any holes in it. You can buy a pipe that is perforated cause this is a thin wall sewer type pipe. But the problem is with a thin... Read More »
Okay we are here at tub number 2 and we are finishing the drainage system with using PVC pipe. You will notice that I've only drilled holes on one side. The other side of the pipe is intact. We are going to roll the pipe over so that the holes are to the... Read More »
We have a second bathtub that we're going to be treating a little bit differently so we have two that we're going to be working with. The drainage system that we're going to use in this one is going to be from a PVC pipe. This is a thin walled what is... Read More »
Okay here at tub number 2, we've got the PVC pipe with holes drilled in the bottom and we are going to add some of those caster bean stalks to the bottom. The reason that I am doing this is to supply a more porous layer down where the water needs to move... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
Retaining Wall repairs scout61 Landscaping & Lawn Care 1 03-26-2009 08:13 PM
$4 per block for retaining wall? tmpyankee Landscaping & Lawn Care 7 09-10-2008 01:22 PM
Retaining wall and fireplace? stf Building & Construction 9 08-28-2008 09:37 AM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 05:39 PM
retaining wall luv2hunt Landscaping & Lawn Care 1 05-02-2008 09:45 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
