Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-28-2012, 12:41 PM   #1
Above ground pool ground cover sheet.
I have a 18' easy set type pool and hate the plastic ground cover sheet that came with it.
It traps water on it from rain and splashing that goes gross if not cleaned up.
So I want to build an area for the pool.
I wondered about using outdoor carpet over sand
I levelled and packed a spot for it last year.
So I would use a bit of sand then put the carpet on it then the pool.
This would allow water to go right through the carpet and into the ground.
Probably use 4x4's for an edging.
Any other ideas of help would be appreciated.
mae-ling is online now   Reply With Quote
Old 06-28-2012, 01:46 PM   #2
creeper's Avatar
Why not just put it right on the sand? Whats the edging for?
creeper is offline   Reply With Quote
Old 06-28-2012, 08:24 PM   #3
Sand around the pool would get tracked in as toys get knocked out.
edging To keep everything tidy, give something to cut grass against.
Old 06-28-2012, 08:27 PM   #4
creeper's Avatar
Very true. I guess the sides must be soft, so you don't want to bang that with the mower.
I've seen some people keep a bucket of water for feet dunking before re entry
New 18' pool on uneven ground rick32 Landscaping & Lawn Care 0 06-13-2012 09:41 PM
SAm light in ground pool trips 15 amp breaker 252609 Electrical 2 06-12-2012 09:55 PM
Above ground pool electrical notsohandymom Electrical 2 06-23-2011 11:12 AM
in ground pool chad2423 Building & Construction 4 09-28-2009 10:41 AM
Above Ground Swimming Pool Filter Tank twaters12 General Discussion 2 08-13-2007 08:06 PM
