Above Ground Pool Busted At The Seems - Fixable? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 11:52 AM   #1
Above ground pool busted at the seems - fixable?
Well, my ongoing bad luck is on a roll.. My above ground pool just busted at the seems and I was wondering if that's possible to mend or not? It's the kind of pool that shapes up when you fill it with water it's an Intex model 15feet wide and 4 feet high. It's ripped through and through!
Girly_girl is offline   Reply With Quote
Old 07-07-2012, 12:19 PM   #2
Rewards Points: 3,410
This should work.
http://www.amazon.com/Above-Ground-D.../dp/B00505SQQA
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Girly_girl (07-07-2012)
Old 07-07-2012, 05:32 PM   #3
Too Short? Cut it Again!
I don't think repairs will hold. A patch kit might hold random repairs but not seams. And you could spend lots that could go to a new pool trying. You might consult a pool company though.
Old 07-07-2012, 05:59 PM   #4
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
That will need to get re-stitched and resealed. I'd check with a pool supply company first. If you can't get any help there, you might look around for whitewater rafting outfits. They might be able to repair something like this, or at least steer you to someone who can.
Thunder Chicken is offline   Reply With Quote
Old 07-07-2012, 07:06 PM   #5
Rewards Points: 6,652
Nope. With them being so cheap, you can throw them away and get another. I have gone through three of the Intex pools now, with first two busting at the seams. The third one I have now, it still holds water, but had to patch a hole in the bottom, where a screw in the cabinet that we store it in, poked through. It will be going in the trash next year, due to getting a larger & deeper pool, since my kids are older.
Old 07-09-2012, 03:48 PM   #6
Happy to help
Lighting Retro's Avatar
can't imagine it would be worth it, and it would probably look rather unsightly.
Lighting Retro is offline   Reply With Quote
Old 07-09-2012, 04:31 PM   #7
Rewards Points: 334
If there is any danger of a "blow out" - I would be reluctant to use it at all.
tribe_fan is online now   Reply With Quote
Tags
above ground pool
In ground pool pipe leaking kelly4172 Plumbing 2 06-20-2012 05:55 PM
New 18' pool on uneven ground rick32 Landscaping & Lawn Care 0 06-13-2012 09:41 PM
Above ground pool cover question joeg679 General DIY Discussions 8 08-03-2010 05:41 PM
in ground pool chad2423 Building & Construction 4 09-28-2009 10:41 AM
above ground pool wiring bobcatnj Electrical 18 09-10-2008 07:00 PM
