6 Or 8' Fence - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 11:19 AM   #1
6 or 8' fence
I can't decide whether to put up a 6' or 8' tall fence. I'm going to do most of the work myself, might hire someone to build the big gate as described below. I'm going use those sharp pointy wood pieces either way to deter fence jumpers.
I like my neighbors but I live on a fairly busy street in a resort area and occasionally get people passing through my backyard. So it's main purpose would be to keep people out and keep a dog in.
Total linear feet would be 182', with a double 10' (5'+5') gate and a single 3' gate included in that linear feet.
For those that have gone 8' have you regretted it? 6' and wish you went to 8'? Worried about sagging an 8' tall 10' wide gate too...
Help me decide! thanks
snosurfa7 is offline   Reply With Quote
Old 01-28-2010, 11:22 AM   #2
Put 2 stakes/post in the ground just over 8' tall
run a string between them at 6' & 8' & then see which fence blocks out enough
Old 01-28-2010, 11:37 AM   #3
This is the kind of fence I would use:
http://www.fencewholesale.com/FWS%20...woodgothic.jpg
Old 01-28-2010, 12:00 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
The problem with a taller fence, IMO, is as much as it keeps people out, it also keeps all your views in. It can really shrink down the feeling in your back yard. The fence in my backyard is only about 4' and is not a privacy type - has done a great job of keeping the dog in and the kids from the park out. I don't think you need to go as high as 8' to get the job done, unless you REALLY want to keep the outside world out of your life (and your views of the outside world too).
My fence, from pre-purchase inspection - the only picture I have of it:
hyunelan2 is offline   Reply With Quote
Old 01-28-2010, 12:02 PM   #5
Before you build, check your local codes. I believe around me anything over 6' has to be set back a certain distance from your property line.
jerryh3 is offline   Reply With Quote
Old 01-28-2010, 12:04 PM   #6
hyunelan2's Avatar
Rewards Points: 692
I was just going to say that too. Here, if you live on a corner lot you cannot have a privacy fence, as it can obstruct driver's views of oncoming traffic. We also can't have a non-privacy fence over a certain height... it's complicated, I know that. Make sure you check it out first.
Old 01-28-2010, 02:20 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
In many locales, you can erect a 6' fence easily, but to put up an 8' fence takes a special permit. In Missouri, where I live, if you put up any fence on the road side of your property, you are liable for damage if someone drives into your yard and hits it. So talk to your insurance company, before you install it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-28-2010, 03:38 PM   #8
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Where I live, fences over 6' are not allowed by code.
brons2 is offline   Reply With Quote
Old 01-28-2010, 04:34 PM   #9
Luckily, despite all of the codes here, an 8' fence is allowed so long as it is set back at least 30' from a public right away...which would make my fence ok. It would only be for my backyard...the front will stay open.
I might try to buy a 6' and 8' piece and get a better idea.
Which leads me to something I have to look into now...I was also planning a split rail fence along my front yard and the sidewalk to keep people from walking into the front yard and the occasional person who decides to drive on it...which would also work only if I used no-maintenance materials and landscaped the area - but now you are saying its a liability if someone hits it while driving? Even if installed to permit?
What if I put bushes/shrubs there instead? Still liable too?
thanks for all the replies
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 05:43 AM
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-04-2010 11:44 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 02:36 PM
