3rd Gear On Mower Does Not Work - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 10:10 AM   #1
3rd gear on mower does not work
I have a John Deere 6.75 HP 21" walk-behind rotary mower (self propelled) model JS63C. My 3rd gear does not work. I cannot find a fix topic in the Troubleshooting section of the User's manual. Any ideas how to fix?
reekeyg is offline   Reply With Quote
Old 09-23-2010, 10:58 AM   #2
Rewards Points: 46
I do not have one, but based on your description, and assuming that everything else is working, I can only think of two things that it might be. First I would look at the belt, and the hardware that engages and disengages it. Does everything move freely, and is the belt in good shape? Second, I assume that there is an adjustable linkage for the various speeds, and if so, perhaps you need to loosen a lock nut, and then shorten or lengthen the shift rod, to compensate for whatever stretching has occurred in the belt. Since you said there is nothing in the troubleshooting section, I would also look at the "pre-delivery" section in the front of the manual, as it seems that these adjustments would be there.
The Following User Says Thank You to DexterII For This Useful Post:
reekeyg (09-23-2010)
Old 09-23-2010, 03:24 PM   #3
thanks for the helpful suggestions
Time limit for getting work inspected? tigereye Electrical 8 12-22-2009 03:56 AM
Switch Gear Pipe work goose134 Project Showcase 1 02-09-2008 12:08 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 03:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
