#1 |
swarring
Guest
Posts: n/a
3 ft garden wall
I would like to build a 3 ft high garden wall around my patio. I've been told that if mortared it must reach below the frostline (42"). It seems a bit absurd to build a wall lower than high. Any experienced/expert/aged opinions on this?
thanks in advance |
#2 |
3 ft garden wall
Use a segmental retaining wall. Segmental retaining walls use special spaper interlocking block (colored & split are optional) that do not require or permit a concrete frost footing. It is only necessary thet the first or second layer of block be below ground. No mortar or reinforcing steel is used.
Google for Allan Block, Anchor Wall Systems, Keystone and Versalok for information and ideas. All of these products are available from local suppliers in the U.S. and from many international concrete producers. |
#3 |
swarring
Guest
Posts: n/a
3 ft garden wall
thanks for your reply. I should have mentioned first:
this is a free-standing wall. Retains nothing. Also, it will be constructed of brick or split rock around a core of cinder-block. I prefer not to use concrete block/retaining wall material. thanks again |
| Display Modes | |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
| This is not a load-bearing wall, right? | AllGoNoShow | Building & Construction | 4 | 01-07-2007 04:49 PM |
| Load Bearing Wall? | Traybae | Remodeling | 3 | 11-05-2006 02:39 PM |
| Load Bearing Wall? | Traybae | Building & Construction | 1 | 11-05-2006 02:01 PM |
