Is 3/4" Crushed Rock To Big For Patio Paver Base - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:23 PM   #1
Is 3/4" crushed rock too big for a patio paver base layer?
I'm laying out a new patio where there was previously a lawn, 26' x 12'. I am putting down 24" x 24" concrete pavers on 4" of crushed rock and then I was going to put landscape fabric on top with 1" of course sand.
I'm concerned that the 3/4" rock isn't compacting down enough (even as I compact it in layers and with water) and I think I should have ordered something with finer particles. Should I add a finer aggregate to the top of the crushed rock so that things lock together better? Is 3/4" okay and I worried about nothing?
Thanks for looking and any advice would be greatly appreciated.
Last edited by WayneGee; 04-21-2012 at 10:48 PM. Reason: spelling mistake and to make question clearer
WayneGee is offline   Reply With Quote
Old 04-22-2012, 06:57 AM   #2
GardenConcepts's Avatar
Rewards Points: 150
The 3/4" size is good, but compaction will be better with fines added.
The fabric should be used between the subsoil and stone layer.
GardenConcepts is offline   Reply With Quote
The Following User Says Thank You to GardenConcepts For This Useful Post:
WayneGee (04-22-2012)
Old 04-22-2012, 09:00 AM   #3
Ravenworks's Avatar
Sounds like you have a good plan so far,you can choke your stone off with some fines.
Next time ask for "Crusher Run" or "304" but as it stands you'll have good drainage.
Ravenworks is offline   Reply With Quote
The Following User Says Thank You to Ravenworks For This Useful Post:
Old 04-22-2012, 10:18 AM   #4
Could I use coarse sand, which I already have, as the fines material and wash it into the rock? I've already placed about 1 yard (of 4 yards total rock) but if necessary I can dig it up and mix it with either the sand or other fines and compact everything again.
Thanks for the response
Old 04-22-2012, 10:36 AM   #5
Ravenworks's Avatar
Yes you can choke it off from the top,that's how its done to begin with.
Old 04-22-2012, 11:20 AM   #6
Awesome, thanks.
Old 04-22-2012, 02:20 PM   #7
Rewards Points: 768
3/4" is NOT okay to use by itself. You need 3/4 w/ fines. There will be little compaction with just the 3/4" rock. Most places have the fines, especially if you had a landscape or rock company dump it. Sand is NOT okay for the base, especially if you are in an area that freezes.
cibula11 is offline   Reply With Quote
The Following User Says Thank You to cibula11 For This Useful Post:
Old 04-22-2012, 06:17 PM   #8
Ravenworks's Avatar
OP knows this,that is why he is going to choke them off,nothing wrong with that.
Old 04-22-2012, 09:29 PM   #9
Thanks for the responses but I guess there are two different opinions here. Will I be okay with coarse sand to wash into the 3/4' rock or should I get fines? If I do get fines will I have to remove the rock I've already put down or will it also wash/ compact into place? I'm in Vancouver Canada so the cold isn't so severe but we do get a few days of freezing temperatures.
Old 04-23-2012, 05:18 AM   #10
Ravenworks's Avatar
Fines would be ideal but sand will work as well ,you can mix them into the existing rock and make the top inch or two all fines.
The idea of coarser rock is for drainage
WayneGee (04-23-2012)
Old 04-23-2012, 07:38 AM   #11
Rewards Points: 768
You'll know if sand works when you compact it. If you have a solid (almost concrete like base) then it's fine. If, on the other hand you can grab handfuls of the base, it's not well compacted. Make sure you dampen the area as you compact, which will make bind together the materials and provide a more solid base.
River rock for concrete base??? snkyfox Building & Construction 4 09-11-2011 02:08 PM
Better - gravel or paver base for cement slab ? timcsi Building & Construction 1 08-19-2011 10:26 PM
Paver Patio: Sand Bed base Semperfi4000 Landscaping & Lawn Care 1 05-17-2010 05:38 PM
Long path to nowhere... crushed rock? rockhead Landscaping & Lawn Care 1 11-20-2009 06:36 AM
Paver Base 7echo Landscaping & Lawn Care 4 08-25-2008 01:51 PM
