22" 5hp Snow King By Murray No Longer Will Propel Itself - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 07:09 PM   #1
22" 5hp snow king by murray no longer will propel itself
my 5hp 22" snow king ultra by murray will no longer propel itself when i squeezt the propel handle. any thoughts??
sda1967 is offline   Reply With Quote
Old 01-20-2011, 12:41 AM   #2
Rewards Points: 212
The friction disc may be bad. Check your manual to find yours and compare yours to a pic of a new one on google. That may be your problem because it propels your blower.
joeg679 is offline   Reply With Quote
Old 01-20-2011, 08:28 AM   #3
A Little Of Everything
Rewards Points: 1,364
Does the propel handle have any tension when you squeeze it? If not, it might be something as simple as needing to tighten it, or a spring popped off.
Mostly though, you're going to have to go exploring. Slowly dismantle things "down there." I think the problem will become obvious fairly quickly.
*If you're unsure and/or a newbie, take pictures before you disassemble things. It's good for the memory. Also, if you want to, you can post some of them and we can see if we can spot the problem.
Good luck!
DrHicks is offline   Reply With Quote
Old 01-20-2011, 09:17 AM   #4
Rewards Points: 1,536
I would start with the rod or cable (if any) attached to the propel handle or lever. There is usually a turnbuckle type adjustment to tighten this up.
Substituting a Murray for Siemens branch breaker mfreeland Electrical 14 12-04-2010 09:04 AM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 12:55 PM
snow plow will not propel itself mrbowma Tools 2 01-03-2008 04:12 PM
