1988 Case Model 688 Excavator - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-19-2007, 09:22 AM   #1
Guest
Guest
Posts: n/a
Hello Folks,
I recently purchased a used CASE excavator to clear my property of stumps, etc. I have a hydraulic control problem with the boom. Does ANYBODY have any experience with this machine?? The local dealership won't even discuss the problem, and are no help what so ever. Thanks for any assistance you may provide.
Old 02-19-2007, 10:58 PM   #2
General Contractor
joasis's Avatar
Probably the service guy at the dealership won't commit to say anything until they can actually see the machine...I am guessing you have gone in and described the problem. Dealerships anymore tend to be focused on making money...and selling you a few parts isn't making their bottom line.
What I would do, if I were you, is look at the local companies that operate excavators, and see if you can get the owner, or a foreman to tell you who services their machines, or if they can recommend an independent mechanic...to at least tell you what you may be looking at.
I can assure you that any work you have done to an excavator will not be cheap, and the parts are really high from Case.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 02-20-2007, 05:17 PM   #3
Guest
Guest
Posts: n/a
joasis,
Thank you for your reply / suggestions. I have done what you recommended, but haven't connected with a competent mechanic as yet. No choice but to continue searching. One would think up here in MAINE with all the machinery (Heavy Equipment) I see everyday. I could connect with somebody who would extend a hand. These folks are tight. Oh well, every road has it's puddles. Thanks again. By the way you aren't a Duck hunter---- are you?
Old 01-08-2011, 12:42 PM   #4
case hydraulic problem
can you describe in detail the problem u are having i have almost fifteen years in the heavy equipment industry and have fixed a multitude of problems and i have first hand experience with this perticular model of machine hope to hear from you soon heath
heathwithanl is offline   Reply With Quote
Old 01-08-2011, 01:24 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... I haveta think he's gotten it fixed, sometime in the last 4 Years...
Bondo is online now   Reply With Quote
Old 01-08-2011, 07:09 PM   #6
sorry trouble ridden i didnt see the date although the 688 is a trouble ridden piece most people ive talked to that have or had this piece of eqipment realize this only too late like the hydraulic pump that is no longer existant or the circut board electrical panel that looks like something out of a radioshack raiod kit gone terribly wrong i wiil pay better attention to the date the thread is posted from now on though thanks for pointing it out heath
Old 01-08-2011, 07:50 PM   #7
Bondo's Avatar
Rewards Points: 594
Ayuh,... No Problem,... It happens to All of Us who answer now, 'n then...
Old 02-18-2011, 04:47 PM   #8
heathwithanl
helloo, i see u know much about excavators and things like this, can u help me? i want to buy case 688 b and what can u say about this machine?
batutra is offline   Reply With Quote
Old 04-18-2011, 08:15 AM   #9
Hi heath, I could also do with some advice regarding a Case 688B wheeled unit (with rail conversion).
Mine has an odd issue, if you press the brake, it also engages drive, if you drive, it applies the brakes also.
The turning joint has been re-built but the issue remains.
In addition, when put into high the gears make a graunching noise
Mark Russell is offline   Reply With Quote
Old 05-21-2012, 05:30 AM   #10
Ravenworks's Avatar
Originally Posted by shikha View Post
The design is basically derived from steam shovels.
Look closely at my avatar,see the steam pressure gauge?
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Skill saw case rsteve12 General DIY Discussions 14 11-02-2011 06:37 PM
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 04:24 PM
