18" Planter/retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 05:10 PM   #1
Rewards Points: 526
18" planter/retaining wall
My neighbor's driveway runs along our property line and, for a length of about 50 feet, is 6 to 15 inches higher than the elevation of our property. There is a slope about 3 feet wide connecting our property at it's typical elevation with the edge of our neighbor's driveway. The slope is a grass and weed filled disaster so we want to remove the grass and weeds, build a wall, fill the area between their driveway and our wall with soil, and use it as a planter. We are in the planning stages and I am trying to determine if standard 8x4x2 clay bricks, mortared and built on a proper footing could be considered for the wall. The wall would be of variable height between 6 and 16 inches above grade, but most of it would be 12 inches and less. Can this wall be made of bricks? Thanks for any advice.
Windows is offline   Reply With Quote
Old 03-11-2011, 06:04 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Bricks and mortar could do it, but could be costly.
Look into segmental retaining wall block (SRWs) since a footing and mortar are no required.
In your area, there are suppliers in your area, but the problem will be the delivery of such a small amount, but brick, sand, and cement also are factors that can creep up.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Windows (03-12-2011)
Old 03-12-2011, 08:54 AM   #3
I don't know what winter is like in Seattle, but if the ground freezes to more than a few inches, take Dick's advice and go with the SRW. Or maybe a dry stack stone wall.
On the other hand if winters are mild without ground frost, the brick wall is a better option if you need it to match your house or other landscaping. A cheaper and easier DIY option would be poured concrete, especially if the drive is sloped.
pls8xx is offline   Reply With Quote
The Following User Says Thank You to pls8xx For This Useful Post:
Old 03-12-2011, 11:43 AM   #4
Rewards Points: 526
I think I will go with an SRW - I like the way it looks and it appears I could build it in a couple of installments which the budget would like. Thanks.
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
