11 Hp OHV Small Engine Has Gas In Oil - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 12:21 PM   #1
11 hp OHV small engine has gas in oil
This engine is on a generator that has been sitting for several months, discovered problem when checking it out before trying to start.
Katz957 is offline   Reply With Quote
Old 10-16-2011, 05:31 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... Sounds like the fuel tank shut-off was left On...
Drain the oil, 'n change it....
Probably oughta pull the carb, 'n blow all the crud outa it too...
Buy a Kit for it, it'll come with a new needle valve, 'n seat...
The only route for the gas to get there, is through the carb, 'n past the rings...
Old 10-18-2011, 10:29 PM   #3
Likely the former but gas can get in the oil if the head is cracked or warped as well.
Try the first advise about changing the oil then consider a compression check.
weehooker is offline   Reply With Quote
Snow thrower engine problem Ultrarunner2017 Automotive Repairs 19 11-22-2011 01:16 PM
12"x12" Tile Layout on SMALL (15"x24") Countertop? mirzai_m Kitchen & Bath Remodeling 6 01-11-2010 01:28 PM
Small engine troubleshooting no mechanic Tools 2 09-21-2008 10:56 PM
Big HVAC Guy vs Small HVAC Guy flysndoc HVAC 4 09-20-2008 12:06 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
