-   -   11 hp OHV small engine has gas in oil (http://www.diychatroom.com/f16/11-hp-ohv-small-engine-has-gas-oil-120277/)
Katz957 10-16-2011 11:21 AM
This engine is on a generator that has been sitting for several months, discovered problem when checking it out before trying to start.
Bondo 10-16-2011 04:31 PM
Ayuh,... Sounds like the fuel tank shut-off was left On...
Drain the oil, 'n change it....
Probably oughta pull the carb, 'n blow all the crud outa it too...
Buy a Kit for it, it'll come with a new needle valve, 'n seat...
The only route for the gas to get there, is through the carb, 'n past the rings...
weehooker 10-18-2011 09:29 PM
Likely the former but gas can get in the oil if the head is cracked or warped as well.
Try the first advise about changing the oil then consider a compression check.
