"Zig Zag" Basement Wall Framing - Need Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 01:00 PM   #1
Hello,
I'm framing an exterior wall of my basement, and for a couple reasons I need to make one portion of the wall further out than another portion.
See picture. I plan on putting a flat 2x4 on the next set of plates, and then continuing on with my studs 16" on center. This should allow drywall to lay flat on the "zig zag."
Is this the correct procedure? Any other suggestions?
bergsj is offline   Reply With Quote
Old 12-12-2012, 01:15 PM   #2
Trucon01's Avatar
Rewards Points: 510
If you plan on drywalling the smaller section, you would need to add another 2x4 as a 'right' nailer on the small wall...
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 12-12-2012, 03:25 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
change the end stud on the left wall to a 2x8 so it comes past the end stud on the joiner wall. this will give backing for drywall and make a stronger corner
woodworkbykirk is offline   Reply With Quote
Old 12-14-2012, 11:35 PM   #4
Registered User
Rewards Points: 5,516
Sill-sealer under the p.t. bottom plates: http://www.greenbuildingadvisor.com/...-building-code
Need the fire-stop those walls at the top and every 10' horizontally, post #21, 22; How to fireblock framing
Gary
Old 12-15-2012, 12:05 AM   #5
Rewards Points: 13,750
http://www.nuwool.com/images/pages/C...iaCorners1.gif
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Floating wall for basement pattyobrien3 Remodeling 11 11-07-2012 04:58 AM
Question regarding framing a basement wall James0816 Building & Construction 0 05-28-2010 09:41 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
