YELLOW GLUE And CRUMBLY BRITTLE TILE HELP - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-12-2008, 07:56 PM   #1
Smile
YELLOW GLUE and CRUMBLY BRITTLE TILE HELP
We are desperately trying to scrape up some old (30ish year old) tile that is thin, brittle and crumbly. It is coming up great in some areas--others it is STUCK. I need to know how to get this stuff up as well as the HORRID YELLOWISH GLUE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS
botal1026 is offline   Reply With Quote
Old 07-14-2008, 04:55 PM   #2
Rewards Points: 5,336
A little detail will help. What is the substrate the tile is attached to? If sheetrock, just remove it to the studs.
Ron
Old 07-15-2008, 07:23 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
If this is floor tile, you should find out if it contains any asbestos. Same with the cement. You could be contaminating yourself and your house.
