-   -   YELLOW GLUE and CRUMBLY BRITTLE TILE HELP (http://www.diychatroom.com/f15/yellow-glue-crumbly-brittle-tile-help-23576/)
botal1026 07-12-2008 07:56 PM
We are desperately trying to scrape up some old (30ish year old) tile that is thin, brittle and crumbly. It is coming up great in some areas--others it is STUCK. I need to know how to get this stuff up as well as the HORRID YELLOWISH GLUE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS:eek:
Ron6519 07-14-2008 04:55 PM
A little detail will help. What is the substrate the tile is attached to? If sheetrock, just remove it to the studs.
Ron
Maintenance 6 07-15-2008 07:23 AM
If this is floor tile, you should find out if it contains any asbestos. Same with the cement. You could be contaminating yourself and your house.
