Wrought Iron Hand Railing - Interio
I have actually had to do the same exact thing. I had a section of iron spindles stuck right into the subfloor and down to the framing, probably nearly 2" deep. I had a lot of trouble getting them out, but they did come out after enough pulling.
I can't say that yours will be the same, but mine were not glued or fastened, just really hammered in there...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
