-   -   Wrought Iron Hand Railing - Interio (http://www.diychatroom.com/f15/wrought-iron-hand-railing-interio-130550/)
jjandm 01-18-2012 08:05 PM
I'm remodelling my living room and I have an old wrought iron hand railing.... i removed the carpet and the iron spindles are right into the wood floor... I removed the screws from the walls (at each end) and I can't remove the spindles from the floor? How would they fasten these to the foor? (would they have glued them?
If I can't get them out, can I cut them and re-mount them using new spinal monts
thanks....
oh'mike 01-19-2012 05:32 AM
Pictures!-----
ARC Painting 01-19-2012 02:06 PM
I have actually had to do the same exact thing. I had a section of iron spindles stuck right into the subfloor and down to the framing, probably nearly 2" deep. I had a lot of trouble getting them out, but they did come out after enough pulling.
I can't say that yours will be the same, but mine were not glued or fastened, just really hammered in there...
titanoman 01-19-2012 03:29 PM
Did you try unscrewing them? From the floor?
