Working Around Pipes On Concrete Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-11-2007, 11:03 AM   #1
Question
Working around pipes on concrete walls
I am wanting to finish the rest of my basement, but there are so many pipes (gas, water, sewer) along the walls that might need accessing that I don't know how to proceed. Do I build a stand-alone wall 12 inches out, not attached to the concrete wall or is there an alternative?
lemones is offline   Reply With Quote
Old 10-11-2007, 11:08 AM   #2
think of it this way: on your first floor or second floor... there are also many pipes... if you need accessing pipes in basement... why didn't you on the second floor/first floor... if you can enclose your first/second floor ... why couldn't you in the basement...
I am not talking about switches/ plumbing clearout etc.etc. those you need access panels...
KUIPORNG is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 05:26 PM
