Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-24-2011, 01:08 AM   #1
SimpleJack's Avatar
Wood stove ceiling port thingy removal?
Not sure what you would call it, but I removed the wood stove I had in the living room and we are never going to use it, so I need to remove that black square thing that has the pipe in it.
I tried accessing it from the ceiling but there is no way to get over to that area of the house from the attic..
I tried cutting around the square piece with a razor blade, but i think it might be bolted in or something? Really I have no idea how to remove this.. does anyone know what I can do to remove the square black piece and part of the pipe that is hanging down so I can close it off with some drywall.
I'm getting ready to paint and this thing needs to be gone.
Any help will be greatly appreciated
Wood stove ceiling port thingy removal?-_mg_8044.jpg   Wood stove ceiling port thingy removal?-_mg_8042.jpg   Wood stove ceiling port thingy removal?-_mg_8041.jpg
SimpleJack is offline   Reply With Quote
Old 04-24-2011, 08:52 AM   #2
Two options. Cut it apart with a grinder with a metal blade or get the instructions from the manufacturer to see how it was installed and reverse the process. The item might be secured in the attic area or it's a friction fit around the pipe if you don't see any fasteners.
Ron
Old 04-24-2011, 10:44 AM   #3
Ceiling support/wall thimble. It appears the pipe is still attached. I think Ron is right, you will need to go into the attic unless it's a flat roof. Is the pipe still going out the roof?
I
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 04-24-2011, 04:55 PM   #4
SimpleJack's Avatar
I
Yes, it's still out the roof top. I have it capped off though. I have no access in the attic to this location in the ceiling for some reason.
So pretty much is sounds like if I can't pop it off the end of the pipe, i need to a big hole and start making a mess?
Old 04-24-2011, 07:01 PM   #5
You should have access to all the areas in the attic. This way you can check on issues that will arise. You can find a stud bay in the area and cut out the sheetrock to provide this access. A simple plywood door with molding, attached with magnets will give you almost instant access.
Ron
Old 04-24-2011, 07:14 PM   #6
SimpleJack's Avatar
Well when I looked up in the attic, I can see the roof slanting and it goes all the way down to the top of the ceiling. looks maybe 20+ feet deep and there is alot of blow in insulation.
Unless there is a small rabbit hole access at the opposite end of the attic opening that can not be seen from the access in the ceiling, which I don't think there is.
Isn't it code or something to have to have full access to al parts of the attic?
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 02:26 PM
wood stove sharing a flue captainkid28 HVAC 5 01-04-2011 12:05 PM
Wood Burning Stove Pipe Question jh756 HVAC 1 08-20-2010 03:19 PM
adding wood stove to boiler flu? wombosi HVAC 7 12-14-2009 06:27 AM
Building a base for my wood stove Verbose Building & Construction 1 10-11-2009 08:06 PM
