Wood Siding + Caulk, I Think I Messed Up... - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 05:41 PM   #1
Rewards Points: 45
Angry
Wood siding + Caulk, I think I messed up...
I just finished replacing about 2/3 of the wood siding on my home and garage. The house is 110 years old and I just replaced the rotten wood siding with new siding (Pattern 105 wood siding). I spent four weeks caulking the bottom overlaping portion of the siding on the house and garage. Some of the boards had larger gaps due to either crooked siding or just old crooked house so I wanted to protect the house as much as possible. I've now been told that what I did was a bad idea which could cause moisture to get trapped. I really view getting rid of all of the caulk as almost impossible after what I went through. My question is, can I simply make an occasional weep hole in some of the caulk to allow it to breathe? Should I strip the caulk on one or two boards on each side of the house? I did not caulk every board due to some of the siding being protected under a porch and others that were unaccessible due to shrubs. Would either of those options be enough to prevent any problems? Any advice or help would be greatly appreciated. Thanks.
Austin
Austin83 is offline   Reply With Quote
Old 07-10-2011, 05:57 PM   #2
kwikfishron's Avatar
Rewards Points: 430
Welcome to the forum.
Is this cedar dutch lap you’re talking about?
What caulking did you use?
Going to need pictures on this one.
How to attach a photo to a post
kwikfishron is online now   Reply With Quote
Old 07-10-2011, 06:21 PM   #3
Rewards Points: 45
My siding is pine, but I guess it can be considered dutch lap (correct me if I'm wrong.) I just used all purpose acrylic caulk, I bought the good stuff, the 35-40 year stuff. I went back to edit my original post, but I forgot to mention that I did not caulk every board due to some protected under a porch and some hard to get to locations.
Old 07-10-2011, 06:43 PM   #4
Rewards Points: 430
I wouldn’t worry about it.
Is what you did common practice, no. Fact is a couple coats of paint usually seals the lap anyway.
I certainty would not drill any holes and chance penetrating the weather barrier.
That wasn’t the picture I was talking about btw.
Old 07-10-2011, 06:55 PM   #5
Registered User
Rewards Points: 5,498
That is Dutch lap, German lap or Cove lap siding. The overlap board is nailed above the lap to let the bottom board move (expand and contract) with the seasonal changes. This also permits drying from water wicking and being solar driven to the backside near the house. It should be primed all six sides against water. No caulking at the laps. Each board needs the air space at the lap, continuous. http://www.forestprod.org/woodprotection06tsongas.pdf
You will get paint blisters if painted with a caulked lap joint; http://www.buildingscience.com/docum...ghts/bsi-028-e
So it’s not a vented (rainscreen) siding? http://www.articlesnatch.com/Article...-Siding/151553
Gary
Old 07-10-2011, 07:35 PM   #6
Rewards Points: 45
Thanks for the advice, after closer inspection it looks like the boards have already expanded and contracted enough to cause the caulk to separate in some places. I tried to remove some of it, and it looks like it would be impossible to remove it. Any suggestions on anything that I can do to better the situation?
Old 07-10-2011, 11:09 PM   #7
Registered User
After it dries I'd try a carbide tipped paint scraper on the caulking, last resort- using a scraper blade with an oscillating power/multi tool. You don't want any of the caulking sealing that joint.......
Gary
Old 07-10-2011, 11:25 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
I hope the 105 siding has changed from the old days, it was tough to keep paint on back then. It also was bad to warp and twist some if it wasn't nailed tight.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-25-2011, 07:07 PM   #9
Where to get siding like that
I need to replace some Dutch Lap Siding on our 80-year-old house. The photo looks like what I need. Where did you get it. Also, thanks for the advice on how to install.
Gary
Gwams is offline   Reply With Quote
Mixture of Siding Material (Vinyl and Wood) jburr827 Building & Construction 2 05-19-2011 08:38 AM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 12:17 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
