Wood Burning Fireplace To Gas - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 09:37 AM   #1
wood burning fireplace to gas
I have a wood fireplace 12ft x 8FT all brick i want to cover the facing with drywall [fireproof ]and put in a gas fire .what are the rules and regulations of enclosing the fireplace ,also what is the best way to do the chimney straight up using an insert or out the back of the existing chimney
steve waterdown on
sjmarciniak is offline   Reply With Quote
Old 01-04-2011, 12:04 PM   #2
Rewards Points: 5,336
steve waterdown on
Venting the gas insert would be based on the units instructions.
Clearances would also be based on the specs of the unit. Double check with your code official if they have added restrictions.
Ron
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Fireplace conversion help needed jandcwright Remodeling 1 10-30-2010 07:04 AM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
adding wood burning to exisiting oil furnace rdmccaw HVAC 4 11-16-2008 07:14 AM
