Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-17-2007, 10:56 PM   #1
Question
Wood against concrete
Is it okay to put white wood against concrete with a vapor barier. If not what would be the best material to use?
ktwags is offline   Reply With Quote
Old 04-18-2007, 05:47 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
(By white wood - I asume that you mean KD grade wood stock)
.......and that depends on what you are referring to as a 'vapor barrier'.
Standard use is 'Pressure Treated' Lumber. (However, you may also use any 'naturally durable' wood. (Wood that is impervious to rot, moisture, termites)
- Build Well -
Old 04-18-2007, 01:25 PM   #3
Question
The reason i was asking is, I want to frame up a wall against a poured concrete foundation and i don't want to have mold. What would be the best way to do that?
Old 04-18-2007, 06:15 PM   #4
Against concrete: Use Pressure Treated Lumber. Use rigid foam board for the insulation. Do not install a vapor barrier (since you are attaching directly to concrete)
You can go one step further and use 'densarmor' sheetrock. HD is even carrying it now. It is a 'paperless' drywall, with a gypsum based core that has mold resistant treatment.
Link for more information:
http://www.gp.com/build/product.aspx...4659&hierarchy
Examples: (rigid foam board not yet installed in bays)
- Build Well -
Old 04-18-2007, 06:29 PM   #5
concretemasonry's Avatar
A question to add to the confusion -
If you attach the sheetrock to the P.T. do you have to use the appropriate nails? After all, there is more nail in the P.T. than there is in the sheetrock.
I know it is required for attaching untreated studs to P.T. plates in basements.
concretemasonry is offline   Reply With Quote
Old 04-18-2007, 06:39 PM   #6
Good point. I would suggest using the grey ceramic coated (treated) screws that can commonly be found at all Big Home stores...
- Build Well -
Attaching wood srtips to concrete wall DIY4EVER Building & Construction 11 07-21-2007 11:10 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
wood or concrete dylan Off Topic 5 02-07-2006 06:15 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
