Wobbly Stair Wood Railing - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-17-2006, 10:33 AM   #1
Rewards Points: 16
wobbly stair wood railing
I have a curved stair case. One side is attached to the wall and the other side is open. The open side has a wood railing with 2 balusters per tread and goes from the second floor to the main floor. The end of the railing at the main floor is not a post but just 4 balusters in a circle. So there is no stronge support at the main floor end. The top of the baluster is attached to an iron rail with nut and the wood railing goes on top of the iron rail. Over 20 years of use the railing is a little wobbly. I have tightened all the nuts on the top of the balusters. But it has little improvement. It is probably the joints between the baluster and the tread is loose. The stair case is carpet covered. I was wondering if I can just toe nailed each baluster without removing the carpet as a quick fix.
DIY_user is offline   Reply With Quote
Old 12-18-2006, 09:28 AM   #2
These over the post systems with outward volute and no bottom
newel post are notorius for loosening over the years. A real
pain in the neck to fix.
The best solution is to remove the balusters on the riser that
supports the volute, and install a newel post with one of the
many bolt-down hardwares that are available.
Sorry, but toe-nailing the balusters won't help for long.
The rail will be loose again within a few days of normal
use.
jbob is offline   Reply With Quote
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
Wood stair covering...pergo? DK75 Carpentry 6 11-02-2006 10:51 PM
Interior Wood Railing mahjohn Carpentry 2 07-05-2006 06:47 PM
How to attach wood to masonry? pgd Building & Construction 2 11-30-2005 05:59 PM
