Wire Staircase Railings - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 06:24 PM   #1
Wire staircase railings
we're trying to do something exactly like these stairs but hoping to find soemthing in canada or atlesat US. vertical because we're not allowed to do horizontal (climbable). perhaps feeney is the best bet but those wire balisters in my link are identical to what we need, and right outta the box.
thanks in advance for any insight.
jamiebond is offline   Reply With Quote
Old 11-06-2010, 06:46 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 476
Couldn't you do that with a single cable with holes drilled and slots in the rail and treads, you could cap off the rail once done.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-06-2010, 06:57 PM   #3
guess so
i suppose so, but you'd need some kind of washer on the bottom of the stair tread, as I assume feenies cables are meant to lock into their bottom rail of their standard 'designRail'. so i figured finding a longer cable to do what was done in the photo might be better and slightly cooler. but ya perhaps a washer and a 40" cable would do the trick.
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
