Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-19-2010, 06:01 PM   #1
Window Trim
Hi,
I would like to either replace or paint my window trim with white and replace the casing with something more updated. I would like opinions. I will definately replace the casing but should I replace the innner trim or can I just paint it? I have attached a few pics. Please let me know what you think.
jerome8283 is offline   Reply With Quote
Old 02-19-2010, 10:29 PM   #2
Window Trim
BY inner trip are you talking about the extension jambs? If so then just paint them and be done with it.
wnabcptrNH is offline   Reply With Quote
Old 02-20-2010, 07:22 AM   #3
Window Trim
yes, the extension jambs.
Old 02-23-2010, 10:26 AM   #4
Window Trim
Why would you remove this wood to only replace it with other wood? It's just a filler piece.
I'd open the side trim pieces to see if they're wide for a reason. They could be there to cover a large gap.
Ron
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
Window Replacement and Trim Red Truck Building & Construction 3 02-11-2010 11:13 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 10:31 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 09:49 PM
